sony z3 compact audio
panayiotistaki
hi guys! i need your help.
I have a problem with the audio of my phone (z3 compact)
The phone's volume is too low.
What can I do to fix this problem?
thank you
12 REPLIES 12
Uliwooly
@panayiotistaki
You have to elaborate, loudspeaker or earspeaker?
if loudspeaker, are you using the preloaded music app?
panayiotistaki
I think that both loudspeaker and earspeaker have the problem.
The quality of the sound is good but the volume is low.
panayiotistaki
Yes, I am using the preloaded music app.
Uliwooly
@panayiotistaki
I think I understand what you are referring to, the reason for it, it's to prevent noise distortion, you could use a third party app to increase the volume
panayiotistaki
I think I ll try to downgrade my phone.
panayiotistaki
The downgrade had no results.
What app do you suggest?
panayiotistaki
I think that the problem is at the top speaker.
It doesn't work.
Uliwooly
@panayiotistaki
You will have to contact your Local support to get it inspected
usc
If the problem is with ear piece volume then try to use ear piece with 16  ohm impedence.
