Sony Xperia E hanging problem partially solved
AkshayVn
I bought Sony Xperia E on November 4th and this mobile performs good in all ways .
It works good with Whatsapp, Wechat,Bbm,Facebook and its messenger without any lags . but lags when I install Viber Because you it has only 512 mb of ram so we cannot except much out of it .
But after I Updated my Phone to the latest Firmware (11.3.A.2.13) it started to lag ..
Whenever I locked my screen and open it after sometime maybe an hour it would lag or gets stuck at the homescreen for more than a minute ..it was too bad for me .. i searched throughout the internet for solutions for this problem and all of them pointed for rooting the phone !!! which i dont like because it voids the warranty  . but it worked well in safe mode . I called up the Sony Service centre they told me to reinstall the phone software which would fix the problem.. if it is not corrected they told that it may be a hardware problem ...
tried reinstalling the software and installed all my apps which is mentioned above and again the phone started to hang after the locking the phone.
after somedays after going to 3 service centres i came to know that the new update  (11.3.A.2.13)  takes a bit of extra ram maybe a 40 mb which effects the apps to run properly . To fix this lagging problem i reinstalled the phone software and Installed Specific apps and moved the movable apps to internal storage   ( NOTE : you can install many apps as you want but some apps use a lot of ram which slows down your device ....) i removed bbm which uses about 50 mb of ram minimum and i used only Apps which use low amount of ram like (Whatsapp , wechat , Fb messemger ) and additionally i am using Instagram Skydrive and Skype which i logout frequently so that is not a problem and games such as Angry birds starwars , space , Temple Run 1,2 and fruit Ninja and 1 big ram **bleep** appp Facebook !!! by using these app i didnt get any lag for the past 10 days now i am happy with it the solution is to remve some of the big ram users app Like ( BBM,VIBER etc) this will give space for the system UI and the Launcher to work properly which makes your phone rum properly If you want BBm or Viber you may have to remove other apps like Wechat , facebook then you can install them . its not a problem with your phone .its the problem with app which uses a lot of ram . to Check out which app uses a lot of RAm got to settings --- apps -- slide to memory and if you want and detailed list install Clean Master app.. Cheers !!!!:smileyhappy
36 REPLIES 36
bhuvaneshdesai
other than the background running apps one more thing that is responsible for hanging is the extend standby mode if you turn it on the phone hangs for a while just after unlocking.
I don't know about the new stamina mode as I have not updated yet
Vengence
Contributor
Facebook is the main culprit.... I recently did a Sony pc companion repair & I haven't signed in to Fb yet... And the phone is quite smooth
I use watsapp, twitter, Google +, Instagram currently but they all run just fine together
jatinz
modified theme
jatinz
also install clean manager and enable wipe after screen lock feature
Tags (1)
Vengence
Contributor
I wouldn't do that.... Wipe after screen lock adds wake up lag
AkshayVn
Ok I will root and let you know..!!! See Facebook Isa not a problem cause Im using fb,fb messenger,whatsapp,viber,g+,instagram and games it's not lagging but if I install bbm or wechat it lags
AkshayVn
And what exploit dif you choose while rooting?
AkshayVn
Sorry for the late replies got exams
Vengence
Contributor
@ Jatin how did you set that wallpaper in settings menu? Or is a lucky screen shot?
jatinz
sorry man i had exams..
select aragon or try another..
no man..its not a lucky screenshot..
n its not wallpaper..
when u have finished installing root browser,u can see the theme apk in system/vendor/overlay/firmware folder
copy the ak to ur external card and in ur pc oen it using winzip..
go to res/drawable-land-mdpi and replace semc_bg.png with the image u want of same resolution (see for the resolution of original image and convert the image u want)
when u have finished converting,replace the original image in apk file
now follow the same step for drawable-mdpi folder(replace semc_bg.png with image u want of same resolution and format)
NB- donot i say again DONOT follow these ste by extracting..Replace the image by just copying the custom image to the apk RAR ..u dont have resorces to re-comress the ak file which needs android sdk
after replacing the images relace the original theme in system/vendor/overlay/firmware folder and if it asks or overright and superuser permission, just select yes.
then click the replaced theme and install it
(If it says error installing,its ok)
now reboot ur phone and select the theme and u r done!!
Tags (1)
