SmartBand SWR10 offline using
Alumil
Hi!
I'm time to time work in places where Internet not available (even GSM signal) up to 5 weeks. And to my regret observed that SmartBand can do nothing for me in this moments. Since no connection to the server - no updates on my Lifelog.
Whether to wait modification Lifelog app for using offline?
Or it's wasted money for me?
Tags (1)
2 REPLIES 2
ranable
I would expect such a device also to be able to display the information to the user even offline and synchronize with the servers whenever available later. I was out of the country without constant internet connection walking  over 10 km.s on a day without really knowing. I have already payed for this device to track my moves and should not have to pay for the constant internet connection to be able to use it properly. What is the point of having an app on a mobile device if I cannot track it instantly? Apparently I could do the same on a desktop machine. Disappointment pure..
Gergo
Hi Guys!
It works in offline mode and according to the user doc it is capable of caching about 2 weeks. Offline = SmartBand is not connected to the phone via Bluetooth. Internet connection is used when data is synchronized among Phone-Server but tracking is independent. Server backup is necessary to restore your activity e.g., when you reinstall Lifelog. The app and functionalities are continuously developed according to the rumors. Try to reset the SmartBand if you have problems.
I also use it and I can confirm that it is trusted about 80%. It has several issues and sometimes not functioning enough well but it's Ok.
I suggest to write down (detailed enough) here the problems without any slug and these may help dev team to get feedback (of course if the forum support team tells them) and locate/fix the bugs.
