Signal issue after lcd replacemet
rzinformatic
Hello to everyone.
I bought a lcd screen + frame  to replace mi z3 with lcd broken.
After change it , I have serious signal problems , outside it works fine ( gsm and 4g ) but in my house or another closer places my z3 has low signal (1 bar ) and  continiously it losts signal.
I open it and check the parts , all looks good, so I have identified 5 parts to may be working wrong :
-Antenna cable coaxial.
-Bottom plastic antenna ( black with some gray lines)
-Bottom board ( where antenna cable connects )
-Top connector socket (in motherboard)
-Top plastic antenna ( It says 'sub1')
So my question is , all this parts works to have signal?  there is a way to recognize what part is not working ?
I want to buy the replace parts on ebay , so I want to know what I have to buy.
Thanks in advance.
Slightly_smiling_Face
1 REPLY 1
Uliwooly
@rzinformatic
Pretty much trial and error unless you get it inspected by your Local support, you could buy a new antenna and check again.
