I have searched this forum and couldn't find anything that was helpful to me, so I started a new post.
The GPS on my Xperia Z1 hasnt worked for a while now, I was hoping system updates would resolve it or it would fix it self somehow.
I have read GPS, here's where I'm at:
I'm wondering if maybe its a hardware issue? I did have my screen repaired a few months ago, I cant remember weather or not my GPS worked since then. Maybe they bumped something inside? They gave me a 2 month warranty so I doubt they will have a look at it for me without charging.. and of course for some stupid reason I'm only doing something about this 3 months later.
Anyway hopefully its not hardware and there is something that I am missing.
Sorry to hear that your GPS is not working.
When you start GPS Test, does it show GPS on in the top left? Do you get any reception bars in the blue box below where in says "In View"?
GPS on but no reception I think, Ive never used this app before so I'm not sure what its supposed to look like
If you tested this with free sight to the sky i'm afraid it looks like there's something wrong with your phone.
What you also can try before contacting a service location is to reinstall the phones software using a computer to make sure it's not a software problem.
You can reinstall the software using PC Companion. Select Support Zone -> Software update -> repair phone.
I have the same problem with my Z1. It doesn't maken connection to any satellite. I think the atenna is broken?
