problem with otg keyboard in my language
7hill
hello. my location is in Iran. when I connect keyboard to my z5 compact , the keyboard is recognaized but I can not type persian (Farsi) - in setting- lannguage & input -physical keyboard - dosen,t have Farsi (Persian) language.
but the experia keyboard has Farsi and i can type farsi with my z5 compact without external keyboard.(with touch screen)
how i write persian (farsi) with external otg keyboard?
my model is : z5 compact - E5823
where should I ask my question? It,s very important for me
2 REPLIES 2
profile.country.PH.title
MarlonUk1
there is actually no farsi Xperia keyboard available ( as far as I have looked for). the keyboard language in the device is actually influenced by the language settings.
for your external keyboard to work, try to change and set as default a farsi keyboard. try to see if this works.https://play.google.com/store/apps/details?id=com.boloorian.android.farsikeyboard&hl=en
7hill
thank you very much for answering but my problem didn't solved.
the physical keyboard menu doesn't change and doesen't include persian with this app - only touching metod include persian which it self has it before.
