Problem in hard reseting menu
Hetch
As i press buttons volume+ and - plus power the phone keeps vibrating without getting in the hard reset menu
4 REPLIES 4
Christofer
Champion
Hi @Hetch,
Pressing the volume up (+) and power key together will force a power off.
If you need to perform a factory reset and are unable to access the phone's settings menu you should instead perform a software repair using PC Companion.
profile.country.RO.title
_alexdon_
@Hetch Xperias do not have recovery mode, so you have to follow @Christofer's advice.
alexdon
Hetch
Thanks for the support, however currently my phone is locked therefore the sony PC ompanion cant access my phone, i need other help to acess it.
Uliwooly
@Hetch
Turn off the phone > run PCC > Support zone > repair > follow the steps (make sure that the phone it's off)
