Hi.
my xperia V had hard brick.and I cant fix that .
It is too bad because there is not anyway for fix Xperia V bootloader but there is way for fix Xperia Z series.(whit s1 tool)
I Loved sony berand but now I hate that because i am developer and the problem there is.... but sony dont alowed to user for fix that.
Have you tried to perform a system repair or is the brick because you tried to root, unlock the bootloader, flashed the wrong firmware or tried flashing a custom rom
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
