My phone is goign crazy in my pocket. Sometimes the flashlight will randomly turn on. Other times it will auto-call someone that I dialed two or three days ago. What do I do?
Add a pin lock or password lock, also make sure that the screen it's facing away from your leg.
'Double tap to wake up' is to be blamed here.
Happens with me when I put my phone's screen facing my thigh. What Uliwooly suggested, put it the other way :smileysmileywink:
@uliwooly Unfortunately, a screen lock doesn't help as you can still drag down the notification bar with lock on. All quick settings are still accessible.
