No quick charging and battery setting missing in the US model
RJS
Hello. The sony x compact is supposed to have qualcomm quick charge 3.0 however, i believe its missing a software update to enable this feature. I have a qualcomm quick charger and it still takes close to 2 hours to charge. On top of this, the battery settings is missing a feature the UK version has called battery care. Please advise. Thank you.
2 REPLIES 2
Uliwooly
Which quick charger model do you have?
settings > about phone > build number
NeoBeum
Enthusiast
If you're on the latest build...
32.2.A.0.305 changes some battery charging settings.
[SETTINGS]>>System - About Phone>>Status>>Charging Optimisation>> On/Off
"Adjust the amount of charge to increase battery lifespan. This may shorten the usage time of your device."
EDIT: Whoops .. forgot to finish.
See if turning that on or off makes a difference to what you can see.
