Need Problem List in Batch 14W22
IrzWin7
Hi Guys. I Think I Need some conclusion with this, i wanna ask something.
Im in the Batch 14W22, if you have the same batch with me, i need you to share some Problem (Pros or Cons. Plus or Minus).
so far in my opinion my problem was only Overheat Camera Turn Off.
Share bellow.
Tags (1)
4 REPLIES 4
m_jojo
The new batchs are fine and the overheating isn't much of a problem/issue. There's high rate of processing going on and it produces heat, the phone is airtight as it's waterproof (DUH!) making it diffuclt for it to cool down and the heat to escape. The only thing that can happen is a software update that can perhaps reduce the overheating a bit but still IT WILL EXIST and it's not much of a big problem. Don't record in 4K for very long and if you're going to complain then remember, it's a phone not a properly built camcorder. You're going to do just fine with 1080p as well.
IrzWin7
Im sorry if i dont catch your advice properly, but the main issue is, im suffering camera shutdown just using a superior auto and manual mode, i just can take just about 10-20 pic. and many user suffering this, NOT THE 4K Recording, i already know that 4K recorder is need so much more investigation. but the real issue not that one, Is the heat just using it
just like this two video :
http://www.youtube.com/watch?v=3yijJvbOu8I
http://www.youtube.com/watch?v=fhERk1nyv78
but my problem wasnt 100% like that, it more longer than this video, imy estimatet time is around +- 8-15 minute, if 20 minute it such a breath free to me. but 20 minute it just rare to me.
Are you getting my problem so far ?
If this software issue why to fix this just take so long ? and not any official statement about this issue. i just need proper promising about this problem.
Thanks for Listening.
m_jojo
Oh, i am sorry for misunderstanding your problem. Face_with_stuck-out_Tongue Indeed this is something that should not be there, have you gotten the latest software update? I think they fixed this problem in the latest update.
Tags (1)
russtyb
I've had touchscreen issues in direct sunlight with this batch, the screen goes crazy touching itself in direct light (hot day) had two replacements with the same issue so far.
