The FM Radio app does not work on my xperia z3 for some reason. There is no sound whether i'm on my headset or loudspeaker. Ok Google feature has been disabled in my phone which was causing it to not work earlier.
try to clear data of the radio fm app.
settings>app>fm radio>clear data
make sure the volume are up. (sometimes they change)
try to open your device on safe mode to test if the radio works
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/td-p/348008
restart your device
If that doesn't work, repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
In case it works when you have the phone in safe mode, see if you have downloaded any apps that listens for voice commands. Also other apps will mute the FM-radio when they use the microphone.
@uliwooly wrote:If that doesn't work, repair the phone with PCC
Bridge (for Mac)
pls update your information with the post kindly made by a user
http://talk.sonymobile.com/t5/Xperia-Z3/my-Z3-radio-Fm-no-sound/m-p/1118360/highlight/true#M31120
thanks
