Camera lens problem,please help me to slove this problem
aihridoy
12 REPLIES 12
profile.country.RO.title
_alexdon_
Have you submerged the device lately?
alexdon
aihridoy
yeah.I did but just 1 min at some water.
can you tell some solution???
_alexdon_
This has been asked many times before. What I see there seems some form of condensation. I suggest you to open all the flaps,perhaps record some 4K videos so the device will heat up and remove that condensation.
alexdon
aihridoy
are you sure water hidden in camera lens?
if I taka some 4k vedios than problem will solve?
_alexdon_
I am not sure it will help,but it is something worth a try. Also, make sure to put the device in a bowl of rice as it seems to absorb moisture.
alexdon
aihridoy
I tried but results are same.take 3 min 4k vedio 3 times.have you any solution?
aihridoy
just noticed my z2 photos got blurry and are not clear as I first bought the phone
so I checked my lens and I found what I thought was smudge and I tried to clean using my RayBan's cotton cloth which didnt really do anything
Uliwooly
@aihridoy
Don't create duplicate posts, contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
geri
Try it to clean with toothpaste I had same issue and fixed with toothpaste
How to do it? Just search on you tube there are many videos there
Hope this help
Remember only with toothpaste not with other solutions
