When I am on a call using a bluetooth headset and a second call comes in the current call immediately goes to the handset. This happens with three different bluetooth headsets from three different manufacturers.
David
Which build number are you on? Check under settings > about phone > build number. Also make sure that you have update to the latest firmware.
