bluetooth connection problem
enrico77
Hello
I have Win7 64bit and want to install xperia e with bluetooth. It does not work. There is a driver problem which Win7 not can solve.
1 REPLY 1
Thommo
You can use wi-fi to connect to your Pc or laptop but you would need to open your connectivity options - Scan and select your Pc then follow the directions
