Battery lasts five days and three hours...
Stenbocken
According to my powersettings my battery suddenly lasts more then five days on stamina mode, how can I reset this, restart did not help, niether did recharge.
Tags (2)
5 REPLIES 5
profile.country.RO.title
_alexdon_
Disable stamina mode,after this go to settings-apps-all-eco mode controller,force stop and clear data.Restart your device and enable stamina back.
alexdon
Stenbocken
Strange but it did not help, the only thing that changed was that it last five days even without stamina. Now it says one day without and five day with stamina again. Maby this true!!! It would be great if my battery suddenly got superpower! I will try to empty the battery completly to see if this helps.
_alexdon_
And charge it to 100%,after that disconnect.
alexdon
Martin27
Is this following a reset or an update? If so, I would advise using your phone normally for a while to let the figures sort themselves out.
5 days on stamina and 1+ days on normal sounds like figures I've seen on mine, however this will change depending on how you use the device.
Stenbocken
No reset no update, it just happened, very strange actually, usually it says one day and a couple of hours. The strangest part is that my battery is still on 89% after almost one day of use . Mayby that indicator also is off...
