Hello,
I bought my Z3 Compact last October 2014. Recently, I've noticed that my battery is draining very fast. In stamina mode, the estimated battery time is 16 hours. Last week, my battery can last up to one whole day. Now, I can only use my phone for 8-10 hourse before it gets to 20%.
Please help.
Hi blindedvision,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Have you tried checking the Battery usage section, this will tell you what is using the battery so much? if possible can you supply a screenshot of the battery usage info?
Hi
I reset my phone. I think it's the applications that I downloaded that bugged the phone.
Thank you and my apologies if I bothered you. I'll update soon if the problem reoccur.
Hi my z3 has developed a serious battery draining issue.
from full charge to zero can be anything from 2 hrs to 30 mins. there are no aps etc running, i have stamina mode on and screen is reduced and goes off as quick as possible.
when looking at power management it is showing that that ANDROID OS is using up the majority of the batery.
i know there are issues with this model with updated OS's but surely this is something more than that.
without a phone of reliability it is worthless and nothing more than an expensive paperweight.
can you please advise a best cause of action?
many thanks
The Judge.
