while in during charging batter drains ,thehe caution is power is not sufficent ,while charging it drains the battery level wat to do please help? in service center is not providing not proper information
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
Try factory reset first, it might help.
