Battery drop on z3
Dariox23
Battery drop on z3
Greetings,
I have an issue with my Z3 battery display percentage.
Once my battery reaches 15%, it starts to drop 1% every minute or 2% por minute(when it normally takes 4 to 5 minutes to drop 1%) then it stops at around 7% and stands there for around 8 minutes.In addition, when i decide to charge it and reaches 98% y takes 30 minutes to reach 100%. is it normal?
I am running 6.0 on z3 and I have had this issue since lollipop.
I tried repair on sony companion and nothing.
Any ideas? thanks
i add some captures https://goo.gl/photos/E5ArDxnpt4e8FNk68
Please help
Tags (3)
7 REPLIES 7
Uliwooly
@Dariox23
I don't see anything wrong with your phone other than the WiFi it's on the whole time
Dariox23
could it be ? do you consider 2% per minute without using anything normal because before 15% it is 1% every 5 minutes thats my concern?. and yes I see that wifi is on but I dont leave it on all the time only when a need. what may it cause these problems?
thanks
Uliwooly
@Dariox23
WiFi it's on, you probably have background apps running
Dariox23
how can i stop these apps from running?
Uliwooly
@Dariox23
You can't, if you have apps and services running in the background the only way is uninstalling them, you could download a taskiller BUT that will only stop them for a few seconds then they will relaunch, draining more battery, it's better to turn off the WiFi, or use Doze if your phone is running marshmallow or STAMINA mode if your phone is on Lollipop
Dariox23
All apps are optimized, and wifi is not always on. i am running 6.0
Dariox23
After I while I managed to stop the wifi for consuming when it is turned off. I disabled always scanning from the location settings and it was fixed. thanks a lot, but it did not solve my main problem with the battery drop.
I add screenshots before the 15% https://goo.gl/photos/aAJSs7hjngzybSz4A
As you see from 18% to 16% took about 10 minutes to discharge with wifi and normal use
but then with 15% https://goo.gl/photos/E5ArDxnpt4e8FNk68 it is when the problem begins even with wifi and the same usage
I hope anyone can give a solution
