Hi! The same thing happened to my XA Ultra. When plugged in, red LED light shows but the device won't turn on. Is there already a fix for this? Thank you.
same here ,,please help for this problem,,,my xperia xa ultra wont turn on,, after i used flash tool to install firmware for my phone xperia xa , after successfully installed, it won't turn on but led is red when connect charger
Hi @gads and @Cej, I am very sorry to hear about that.
Have you had the chance to read my previous replies for assistance in troubleshooting this? If that did not resolve it, then I'm afraid that I can only refer you to have your device sent to service.
In order to have your device sent to an authorized service center, I recommend that you get in touch with your Local support in order to be assisted. They are well informed regarding the service routines, warranty terms and consumer laws in your local market. I wish I could assist, but since I am based in the Nordics I am afraid that my market knowledge is limited to the one I'm situated in.
@gads wrote:same here ,,please help for this problem,,,my xperia xa ultra wont turn on,, after i used flash tool to install firmware for my phone xperia xa , after successfully installed, it won't turn on but led is red when connect charger
hi did u solve your problem?cause we are same. i flashed it using flashtool after flashing, device did not boot normally it show red light notification instead.
hello, I'mhaving the same problem. Phone started playing up with screen yesterday, it won't let me unlock and screen kept flickering. then the screen went completely black. I know it is on because I still receive calls and messages. I've triedeveruthing. When I take the sim and sd card out it restarts and goes black again. I've tried holding power buttom and volume as well, I've tried performing a system reset with the pc but it won't work because I can't switch the phone off.
Anything else I could do before sending phone to repair please?
i have the same problem, but in this case i used flashtool to upgrade my phone, but when i try to turn it on, it wont start. i plugged into my laptop but i cant go either on flashmode o fastboot mode just the red light goes on, the same when i connected to the charger.
can someone tell me what can I do?
I am having the exact same problem and i have tried everything you have listed above but it still does not turn on and is not charging. i have had it plugged for over 6 hours and the red led still shows but no charge. what should i do in ths case?
Hi , i am having the same problem, have sent the phone to the repair/quote address, just had a reply but guess what! this problem is not covered by the warranty!!!
seems like a common fault , but something that is not repairable , been offered a replacement for £140!! some warranty!!!!!!!!!!!!!!!!!!!!
Yesterday my XA starts to swich off with out a cause. Today is death as people says in the post, I did everything but nothing works.
