When I play music through the music app, there is a problem with the audio setting. the automatic optimization and dsee hx are working correctly, but the sound effect , dynamic normalizer and clear audio+ aren't working as intended. At first all those option are working normally, but after a song(FLAC) end and transition to the next song(FLAC), those option that I stated above will not work any longer. If i manaully skip to the next song, everything will be working again. If i let those Flac file "flow" naturally to the next (FLAC) song, those option wont be working again. By the way if it's flac to mp3 or mp3 to mp3 or mp3 to flac, those option work normally. The flac isn't HR by the way. I also tried to replicate this issue in safe mode. Unfortunately, I got the same result. I think the issue has been in my phone since marshmallow. I thought that by upgrading to nougat the issue would has been resolved,but the issue still persist. Please inform this bug to the developer. Thank in advance.
Build number:34.2.A.0.311
Model number:F5122
