has it got a USB or flash card slot
symwolf125
1 ACCEPTED SOLUTION
Watashiwateshdes
Contributor
Here is a breakdown on both products from the Sony.co.uk website
Tablet S
SD, SDHC memory card x1
Hi-Speed USB (USB 2.0) micro A/B connector (host/client support) x1
Tablet P
microSD, microSDHC memory card x1
Hi-Speed USB (USB 2.0) micro B connector  x1
As for the max memory sizes it supports, nothing yet so on that front, I would recommend waiting until they are launched. Hope that helps.
2 REPLIES 2
BradleyUK
It has a USB port, but I don't think it has a flash card slot.
Watashiwateshdes
Contributor
Tablet S
Tablet P
