- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KDL-42W653A - Wall Bracket?
I have just upgraded our main TV from the Sony one listed above, so now this one is *hopefully* going in my bedroom. However, have discovered that the wall mount for this TV is actually the stand it sits on, and that there was another piece that fixes this to the wall, which we now don't have. This built in bracket also does not swivel/tilt etc, and I would need one that has an arm so that the TV can be moved into several positions.
Of course, I purchased what I thought was a good bracket - perfect for the weight and size of the TV. THEN discovered it won't fit this TV and that Sony appear to have their own standards as to what you can use.
My question (finally getting to the point) is: can I get a bracket that WILL fit this TV, or can you only use the one Sony provide that does not let the TV move around.
Thank you so much for getting this far - any help is much appreciated!
