I swap between my phone and laptop a lot. When I turn on my Bose QC35ii, they automatically pair to both devices. To swap between them, I just hit pause on my laptop and hit play on my phone and the transition is seamless.
With the XM3s, I have to turn off bluetooth on my phone before I can connect to my laptop. Then I have to switch off bluetooth on my laptop and reenable bluetooth on my phone and manually hit connect before I can switch back.
This is terribly slow and completely unusable. A $15 pair of bluetooth earbuds can do this with no problem.
I plan to return the headphones unless this is resolved soon.
Any fix for this planned?
Hi @KevKevKev and welcomewelcomewelcome to the Community
You could possibly check with Support about this in case there is a workaround
Just wanted to add my vote to this. It’s incredibly frustrating to switch BT sources. Like the original poster I have just bought these and think I might return for the Bose models if there isn’t a straightforward way to do this. A £300 pair of Bluetooth headphones that cannot swap sources is a ridiculous shortcoming.
