WH-1000XM3 can't get mic to work
I've checked out some solutions for this but I can't get the microphone to work on my PC (windows 10). There is no option for an "Input Device" in sound settings so I went on sound settings and noticed that the "WH-1000MX3 Hands-free AG audio" was turned off. When I turned it on I could use the microphone but as a result there was no audio coming out of the headest. (Even though the "output device" was WH-1000MX3 stereo)
It seems you can't have both of these two things connected and working simultaneously, any advice?
1 REPLY 1
Pentium_Gladio
Specialist
According to Sony support, you can't have both working at the same time as this is a limitation of the Bluetooth profiles. That said, this also isn't a gaming focused headset, so it was never designed to work for this use-case in the first place.
Pentium_Gladio
