Hi. My WF-1000XM3 earphones had been working perfectly until yesterday. Now however when I use them on a Windows desktop connection the volume is reduced by about a half. They work fine on an Android connection.
I have checked on the Sony Headphones connect app and appear to be on the latest version 3.0.0 I have also been into Device Manager and tried both updating the drivers and uninstalling the device (and then restarting). My old WF-1000X earphones are working normally on the same desktop.
Anybody got any ideas?
Double check that you're connecting to the correct model number mentioned in this article (mainly WF-1000XM3 instead of LE_WF-1000XM3) and also that you're using headphones mode and not headset mode.
Hope this helps!
- JD
Hi Simon, I guess this is not an issue with the headphones either, try reaching out to your PC's support. If you want to double-check this, try a different phone, like an iPhone.
