WF-1000XM3 ear buds
ricgray24
WF-1000XM3 ear buds
Is is possible to replace the internal foam filters as mine have become clogged and difficult to clean, if it is where can I get new ones from.
2 REPLIES 2
profile.country.PH.title
MarlonUk1
unfortunately there in no user changeable part of the ear buds except for the ear cups. have you tried cleaning it with a q tips damped with rubbing alcohol?
SkyNet404
Specialist
You could also try these air-pressure bottles to clean it, but if it's the same you will need to send it for repair sadly.
