Hi.
I have a Sony NWZ-B183F MP3 Player and I have the navigation buttons broken.
Even though the device is fully functional, it's useless. I can't find any replacement buttons online. Is there any quick fix for this?
(The metal contacts underneath the buttons are accessible. I tried shorting them using a jumper wire and that gave me the functionality of "next song" button. But I don't know how to get the "previous song" button.)
Thanks,
Omkar.
Hi @ospadaki and welcome to the Community
It may be worth you contacting EET Europarts, Sony's
parts retailer, on +44 (0) 333 241 9271.
You could also contact Sony Support on +44 (0) 2073652810
if you have no luck.
Last option would be to check Ebay etc for 'spares or repairs' sales of your model.
Cheers
