Sony SRS-XB33
152bobby
Sony SRS-XB33
I have had the SRS-XB43 for a while now and I have just bought a XB33 to use in the garden etc.
I assumed that like the XB43 it had a 3.5mm socket, which it has not, still a good speaker though and I'm keeping it.
Does the type C or the USB sockets take a 3.5mm with the appropriate adapter, or are these solely for charging only ?
2 REPLIES 2
Peter_S.
I don't think that this will work but I might be wrong. However, I even don't know such an adaptor.
Cheers
152bobby
The adapters do exist.  For example, I have a Google Pixel 5 which only has a type C port and it has no 3.5mm headphone jack(like most phones now).
I have to use this adapter to use Headphones with the Pixel 5.
I could just try using it in the Type C port on the XB-33 and see what happens, but I don't want to risk it in case it damages either the XB-33 or the Pixel 5.
Thanks for your reply.
