when using my usb for first time and downloading the software for my NWZ-E585 I'm not sure if it loaded right, also I don't have explorer as my default, if I delete the program and load it again, do I have to use explorer? is there a link to this software so I can download direct for my NWZ-E585
Also I am confused about the media go where do I find it.
Thank you for any help given
Hi there
Try the Media Go software, which can be downloaded from:
http://mediago.sony.com/enu/download
Cheers
Hi there
Cheers
I Thank you so very much for all the help you have given me in the past few days, you have been most helpful, I:smileyheart: this site. Thank you Thank you, best wishes Mags
You are most welcome
