Sony NW A55 no sound control when Bluetooth connected
Cblake843
When I connect Bluetooth to my portable speaker (W-King) the volume option is not present. I’ve tried all the settings/ protocols but I can’t change the volume. BTW minimum is too loud and even reducing volume before connecting Bluetooth is still too loud for me.
What’s going on?
1 REPLY 1
Peter_S.
Probably the speaker doesn't support volume control via BT or there's a communication issue between both devices.
I would check if both devices are running the latest firmware.
Cheers
