Hi!
Can anyone help me find a wiring diagram from the Sony MEX-BT3700u?
I was given a gift of the Sony MEX-BT3700u but I am not sure of the correct wiring. If its possible I shall be grateful if someone help me decode the different coloured cables.
Thank you
Ekendra
Hi Ekendra,
You can find it on Sony's website - it's the Installation Guide download you want - it gives the colour coding for the wiring.
This is the link:
http://support.sony-europe.com/eve/audio/mex/mex.aspx?site=odw_en_GB&m=MEX-BT3700U
Hope that gives you all the information you need
Hi Ekendra,
This is the link:
Thank you Drumzman,
Greatly appreciate your help.
Kind regards
Ekendra
