Problems with car audio steering wheel controls
tweacle
Hi there
I have a ford focus 56 plate and a CDX-GT350 radio/cd.
When I plug in the steering wheel control wire into the back of the radio I cannot change the volume at all on steering wheel OR radio . When I take it out the volume on the radio unit works again.
Any idea's??
1 ACCEPTED SOLUTION
Drumzman
Hi tweacle,
Not sure what you have, but usually you need two third party adapter leads to make this work: a universal lead for Sony (in this case) and then a specific lead for your make and model of car.  I have used these guys previously (Connects2) who I've found to be very good:
http://www.connects2.co.uk/c2home.aspx
Not sure if they have compatibility for your car, so might be worth giving them a call to find out if the leads are available and which leads you need.
Hope this works out for you! :slight_smile:
1 REPLY 1
Drumzman
Hi tweacle,
