HI,
can i recover an mp3 player thats been dropped in water, have tried leaving in rice 36hrs
thanks
Hi @dazza2969 and welcome to the Community
Sorry to hear you're A15 got wet 😞
Did you try to power it on? (If not then don't)
Did you remove the battery straight away?
This can apparently sometimes help.
Check if the unit is totally dry before attempting to power on.
If you still have no luck then you could try contacting supporton
to see if they can recommend anything.
Cheers.
hi jumpy,
thanks for info, did turn on screen blank then off. have just taken delivery of new NW A45R. its for my daughter who is autistic and loves her music, think i will phone support see if i can get A15 repaired before recycling again thinks for the advice
thanks
deryne
Hi @dazza2969
Sorry for the delayed response.
You're welcome
Let us know what support say as it may help others in the same situation.
Cheers
