I have a walkman that I find easy to use and did a lot. Now I cannot find the software so that I can update my playlist.
Does any one know how I can get hold of this software so I can use my walkman again.
many thanks
Hi @kagordo31 and welcome to the Community
Did you mean the NWZ-B162?
Which software were you looking for?
The supplied software is on the Walkman,
the manual says:
Yes, I can see that the software should be in the product. However the guide indicated that the device could be re-formatted to increase the user space for audio. I have not used this product for some time and I guess that I must have deleted the requested file. Do you know if Sony have a copy themselves that they could let me have?
Any help on this will be appreciated.
You can use Windows Media Player, also in Windows 10...
