I have recently purchased an NWA 55 (UK edition) and am hoping someone has the solution to this.
I have all my music saved to my HP PC in Windows Media Player. All ripped from CD's that I own. It all shows ok on the PC.
When I synced the CD's to the NWA 55, it has taken the first song from 120 of my 440 albums and dumped them at the bottom as one "album".
I have Synced all my music to a Sony 64gb memory stick for use in the car and it did that ok, so it doesn't appear to be a PC issue.
Does anyone know how to solve this issue in the NWA 55 ?
Thanks. 👍
Hi @Drummer1234
I\d suggest using the Sony Music Centre app to transfer you music to the Walkman, or to simply drag and drop files on there if you already have them sorted into folders and playlists on your PC.
Win_88
