NW A55
whads354
NW A55
Hello, I'm thinking of buying a NW a55l mp3 player as my old Ipod Classic is dying. I have a large music library stored in itunes as Apple lossless m4a files. Will the NW a55l accept and play m4a files or will I have to transfer the music to another format? If it does accept m4a files will I be able to play them using bluetooth to my earphones? I understand this is a problem for some of the budget mp3 players. Any advice appreciated.
Thanks, Steve
2 REPLIES 2
Joe_Dohn
Specialist
It does support m4a files according to the Help Guide, and there shouldn't be any issues with Bluetooth headphones either.
whads354
Thank you for your reply, very helpful.
