Can anyone explain why some of my music files within my library on my Windows laptop have a warning symbol and won't play?
If they don't play in any player (Music Centre or others) the files may be corrupted.
Some of my albums have the warning sign (an exclamation mark within a triangle). If I double click a track within the album the sign disappears and that particular songs become playable. If I repeat it for each track then the full album becomes playable and the symbol disappears.
Other albums won's play regardless, so I just delete them. The problem may arise because I'm importing from an external drive. Now, I import from the external drive to a drive (c drive) on my laptop before I import the album into Music Centre.
Thanks.
It seems it was an issue with the system/app not resolving the proper location of the file and only doing that when you start playing it, or could be corrupted (the ones you had to delete).
In any case, if it's working completely fine for you now, mark the last post you made as the solution so others know where to look ^^
- JD
