MEX-N4300BT car stero not playing songs in correct order from USB
Frank2_
I have a MEX-N4300BT car stereo and when I insert the USB  the songs in the album don't play in the correct order and it drives me crazy.  The file numbering is correct and the mp3 tags are also correct.   Anybody knows how to fix this problem?
1 REPLY 1
Peter_S.
To my knowledge the files are played according to the file name.
If you add a leading number to the file name, the play order should be OK.
Cheers
