deleting, how to - walkman E394
drofyb
I have a new E394, and a Windows 10 laptop, and have installed "Music Centre for PC" as instructed (presumably a replacement for Media Go which I used with my old walkman).  the online manual, chapter 39 says as follows :
""Click in the bottom left of Music Center for PC to open the list of content on the Walkman.""
however I have no such icon !
any help greatly appreciated, thanks.
4 REPLIES 4
Anonymous
Not applicable
Hi there,
Which laptop are you using? and is updated?
Best wishes,
M
drofyb
Thanks M,
I don't know whether this is what you want. I am not technical nor a PC expert.
I have found that I am running Windows 10 home incl feature update 1903 on 18/7, and I home screen 280719.pnghome screen 280719.pnginstalled Music Centre for PC on 16/7, version 2.1.0.  I purchased the Walkman E394 on 12/7.
see screen print of MC for PC attached, sorry it's a bit untidy.
what next please ?!
drofyb
drofyb
me again M,
I used to delete items from my old Walkman by clicking on the Power button, top right just as it is now, and then following the sequence , but this button doesn't seem to have the same functionality.  I didn't need to use MediaGo for deleting. does the E394 have a similar delete functionality ?
thanks again,
drofyb
The_Black_Rose
Specialist
Hi Drofyb,
I've just searched with the word delete in the Walkman and it seems like it doesn't have any sort of buttons for delete, it has to be done from the source you transferred the content from. I'd recommend having a look here:https://helpguide.sony.net/dmp/nwe390/v1/en/contents/TP0000892247.html?search=delete
Cheers,
The_Black_Rose
