Wireless with RA304
Manner
Wireless with RA304
Hi There
I have the RA304 desktop with the LAN access point for the media receiver.
My brother across the road has a wireless modem. Is it possible to use the access point to get access to this wireless modem?
Manner
11 REPLIES 11
kee-lo_
If he's within 100M you should be able to
Manner
How can I do this?
I thought that the access point is only capable of sending out - rather than receiving?
I've just got a USB wireless dongle by Belkin that has let me connect to his computer.
Cheers
Manner
kee-lo_
It sends/recieves
Go to Start > Connect To > Show Available Networks
Manner
Hi Kee-Lo
I cannot see the
" Start > Connect To > Show Available Networks"
I see
Start > Connect To > Show All connections
Is there something in the device manager that I can check to see if my RA304 has the hardware to use the LAN access point to connect to a wireless network?
Manner
kee-lo_
What do you see there? LAN, 1394 and WLAN?
Manner
I see
"1394 Connection
Local Area Connection"
and thats all.
Cheers
Manner
kee-lo_
Do you not have the access point that came with the machine? This usually connects to the ethernet port.
BartK
Dudes, please... You cannot connect an accesspoint to a wireless modem unless that modem can connect to an access point. You can also not find an access point connected to a LAN port in WLAN settings since there is no WLAN on this vaio. An access point is, and the name sais it all, a point of access. It allows OTHER wireless devices to connect to it, it will then act as a link between these WLAN devices and, if connected, a network or network card. So it is your brother that needs to check if he can connect to your access point and not vice-versa. these chances are however very low.... Since you don't have a WLAN card but only the access point you CANNOT connect to the modem.
Most likely or the modem is already an access point, or it can only accept ad-hoc connections directly to a WLAN card. In both cases you cannot connect to it with the materials bundled with the unit. I hope this clears this out a little bit.
kee-lo_
So you can use an access point as a booster?
