wifi not connecting sony vaio VGN-NW24S
Carlbharj
I have a VGN-NW24S. I switched of some startup programes and now do not see any network connections.  Have switched on all the startup which  I had stopped.  Still no luck. Running Windows 7.Any suggestions
3 REPLIES 3
Peter_S.
Hi Carlbharj,
You don't see the network icon or you don't have a network connection?
Maybe you accidentally disabled the WiFi switch:
Cheers
Carlbharj
Thank you for your message. The Wi-fi switch in the front is on and I have tried switching it on and off and then back on. I can connect with a hard wire but not wireless. May be the Wi-fi has been disabled and I need to enable it. Any suggestions on how I can do that?
Carl
Sent from my iPhone
Peter_S.
Hi Carl,
Maybe you disabled the VAIO smart network function.
Can you check if it's enabled?
Else you might want to re-install this feature:
https://www.sony.co.uk/electronics/support/vgn-series-vgnnw200-series/vgn-nw24s/downloads/Z0000717
Cheers
