tonyboy60
VPCF13M8E problem
Hi, i have a vaio VPCF13M8E, when i try and burn a dvd i get make sure you have the latest firmware installed on your Device? also everytime i see the files to burn theres a setting file there on files to be burn,and sometimes TRACK00 there aswell? i hope you understand my problem sorry i am not that good on a PC. Thanks  it also says my window media is currupt? how do i reistall? thanks
Message was edited by: tonyboy60
3 REPLIES 3
tonyboy60
anybody please help?
Blencogo
Hi tonyboy60.
It seems nobody here has had this same problem.
Are you using the original Sony Operating System and have all Microsoft and Vaio updates been installed?
If so, all I can suggest is that you speak to Vaio Support to see if they have a solution.
tonyboy60
Hi, thanks for the reply, yes windows 7 and vaio updates are all upto date?
