Voltage on motherboard of RX 402
Noel
I use PC Probe firom Asus tek and i read a tension of 15V for 12V. The RED is in use.
First Can I use PC probe for this MB?
Secund If yes; what I must do?
Thanks for the reponse. Alain Noel :smileyrolling_eyes:
10 REPLIES 10
robpaxton
I would ignore the 'results' PC Probe has given you. The chances are that it is wrong and that the board is not fully supported by the software.
I would probably do what William suggested at the beginning, uninstall it and pretend it had never been installed :slight_smile:
Regards, Rob
