Vaio w1/fan
DarkTirol
Vaio w1/fan
Hi, I have a W1, I think it is no bad pc, the only thing I really hate is that the fan is starting very fast and is then very loud........is this normal ?
Thanks Tom........and excuse my bad english
2 REPLIES 2
guitarkid
standard fans are quite loud anyway, and with the w1s fan being on top of the desk with you(not stuck underneath in some tower) it will seem louder..
i only really hear mine kick in when im playing mame, ive not even heard it when burning a dvd, and never when watching tv/dvd so if you think your fan is being a little erratic it might be worth checking out, or if its giving a rattling sound it may be loose, im not too sure im just saying that i only notice mine when playing mame...
i think aswell the dustier it gets the more it has to work.....
Psaila
I feel all Fan's seem to have there momments , I find keeping a good supply of Canned Air helps to free dust , But I Find the Fan not bad at all to be honests .
