Vaio S1XP and cd/dvd drive
royse
Unfortunately my cd/dvd drive does not recognise cd and dvd's anymore. Using google I found a lot more occasions of this same error. For example:
http://www.siliconpopculture.com/sonytr/viewtopic.php?p=51888&sid=8b071a361f4dc0742ee2d8f8e53bd367
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=34153
It seems that a lot more people face the same problem. Is the hardware broken, error during manufacturing, software error or just simply bad luck?
4 REPLIES 4
Blencogo
Hi royse and welcome to ClubVaio.
If you go to Device Manager and expand CD/DVD ROM Drives, are there any errors or yellow warnings against your drive?
:thinking:
royse
Everything is normal, no warnings or errors in the device manager.
Strange thing is that the drive seems to work as normal, only when you put in a cd or dvd and try to access it via explorer, the discs seem to be completely empty.
royse
nobody?
royse
Apparently not
