VAIO Info Centre
paulwhyte
VAIO Info Centre
:slight_frown: Using the Product Recovery CD, how do you get VAIO Info Centre to work so that you can access the hardware and software guides? I load the icon, go through the menus, then click the options, but nothing happens.
2 REPLIES 2
William
Hi Paul,
Perhaps I am missing something, but why are you trying to access the guides on your recovery CD.
They should be preinstalled on your hard disk.
William
Stephanius
The way to access the documentation varies from model to model.
What is your model?
