Hi there,I have just got a vaio FS415B it has built in wireless and would like to use it but I dont know what I need to use it/set it up etc?
Any ideas? thanks x:smileyhappy:
Hi
Do you have an internet connection or other PCs to connect to?
Hi,yes I have a desk top pc ,I get my net through the desktop pc,im on broadband,i dont know if its cable or ADSL,sorry x
OK
Do you get broadband from:
BT, AOL, PIPEX, Wanadoo, Bulldog or Virgin?
Or is it NTL or Telewest?
I'm with Tiscali and connection is 500k
I think its the USB connection x
You can, if you wish, also connect the router to your desktop pc by way of the ethernet port.
Looks like this...
