Sony Vaio VPC-EJ3K1E CPU upgrade
PawelGraj
Hello, everyone! I'm thinking about upgrading CPU in my Vaio to something better. Right now the notebook is equipped with Intel i3 2350M. I'm pretty sure that any 2nd gen dual-core CPU will work, but what about something with 4 cores (2670QM, 2760QM)? They all fit into G2 socket (a.k.a rPGA 988B). After extensive research I found only 1 link with pretty useful infomation. I've already contacted the author but I hope that any of you guys has some more information about CPUs I can go with.
Any assistance is appreciated :slight_smile:
1 ACCEPTED SOLUTION
PawelGraj
I was able to contact the guy from my post. The rest of the story is avaliable here.
3 REPLIES 3
Mick_D
Moderator
Hi Pawel, I see you have a response to this question on another thread; would you mark this one as answered and maybe link to the solution?
Mick
PawelGraj
profile.country.FI.title
Juez_y_verdugo
Yes it is posible to update to i7-2630qm without update bios, and it works at 100÷ cpu usage fine.
More details on reddit: https://www.reddit.com/r/laptops/comments/hx38w9/update_cpu_sony_vaio_vpcej3k1e/?utm_medium=android_...
