Hi everyone,
I'm a new Sony laptop owner and I've just discovered this very informative forum so I thought I'd join in!
I bought a Sony Vaio SZ1XP last week and whilst I'm pleased with the build quality, the general performance seems to be a bit lacking when running demanding software, eg Cubase Sl, with performance not much better than my old 1.8 GHz desktop (with only 512 MB of memory!).
I downloaded and ran CPUZ, which reported that the RAM (1GB) is running at 266MHz, rather than the 533MHz it's supposed to be.
I wonder if anyone else has the same problem; I'd be grateful for any feedback.
All the best
warble
16x is about the highest for laptops at the moment, though I have seen some 24x around
Hi Thalamus and Kee-lo, thanks for the replies, I'm looking at the Fresh Diagnose website right now-looks good. I was unaware that there is such a difference in speed between laptop and desktop Cd -writers, such is my ignorance! I'll just have to be more patient than usual when burning discs.
On the positive side, the onboard audio chip in this machine is excellent, and is giving great results with voice recognition software without the need to buy an additional soundcard.
Cheers
warble
Hi Warble,
Glad you liked the link...:smileyhappy:
HI Blencogo
thanks for that, as you must have noticed I'm completely ignorant in this area! I was a little concerned that Sony had put the wrong type of memory into my machine, so you've put my mind at rest. I have a lot to learn about computers, even though I've been using them for a long time.
Cheers
Warble
Hi Blencogo
that's a very illuminating Wikipedia entry-just what I needed, so thanks for that!
When it comes to upgarding the memory in Vaio's, Sony make a big deal about only using their own (ludicrously expensive) RAM. Is it possible to use any other (cheaper!) brand, eg Crucial Memory?
Cheers
Warble
Actual writing speed is 16 x maximum, and according to Sony tech (who are absolutely useless and clueless, and took 5 days to check with the engineers in Belgium) this is within spec.
warble
Hi warble,
I use Crucial memory in both my Vaios. Works fine.
Can't recommend anyone to purchase the very expensive Sony modules.
